Asus Strix GeForce GTX 960 DirectCU II OC 2GB Overclocking Results
Using the Asus GPU Tweak software, we set the power limit to the maximum value of 115 percent and did the same for the temperature limit – 95°C.
We then managed to add an extra 100MHz on to the core frequency, taking it to 1,354MHz. This gave us a rated boost clock of 1,417MHz, but it was actually boosting to a constant 1,518MHz, which is fantastic and on par with the best we've seen from second-generation Maxwell GPUs thus far. This core overclock is 8 percent quicker than Asus's settings, and 20 percent faster than reference. We tried to increase the clock speed even more by increasing the cards voltage's, but even with the minimum voltage increased by 150mV and the maximum by 50mV (the maximum allowed in both cases), even an extra 20MHz wasn't possible to keep stable.
We also managed to get the memory up to 7.9GHz effective, which is 10 percent quicker than Asus's already overclocked memory and again on par with the best we've seen from Maxwell products.
Nvidia GeForce GTX 770 2GB
AMD Radeon R9 280X 3GB
Asus Strix GTX 960 DirectCU II OC 2GB (OC)
AMD Radeon R9 280 3GB
Nvidia GeForce GTX 760 2GB
AMD Radeon R9 285 2GB
Frames Per Second
AMD Radeon R9 290 4GB
Frames Per Second
AMD Radeon R9 295X2 8GB
Nvidia GeForce GTX 980 4GB
MSI GTX 970 Gaming 4G 4GB
Nvidia GeForce GTX 780 3GB
AMD Radeon R9 290X 4GB
Nvidia GeForce GTX 750 Ti 2GB
AMD Radeon R7 265 2GB
2000
3000
4000
5000
6000
Score (higher is beter)
